Hi guys,
I'll be replacing an old double oven and electric hob with a new single oven and induction hob.
Currently there is a 30amp breaker feeding a 2 gang cooker switch, from the switch there is a single cable that goes to the oven and then another cable twinned with it (twisted wires on the oven terminals!) that goes to the hob.
Should I get the current cooker switch replaced for a dual switch / socket type?
The oven has a total connected load of 3.68KW
The hob has a total connected load of 7.2KW
So my questions are.....
1. Is the 30amp breaker enough? Should I change it for a 40/45a?
2. Should I get the current cooker switch replaced for a dual switch / socket type? Will the 13A socket be suitable for the oven?
Thanks in advance,
Martin
Thanks in advance,
Martin
