Powermax 155x, approx 6 years old, had new programmer a year ago. The fault is that in general I can only get hot water when the central heating is on. Although sometimes can briefly get it if just water turned on and boiler cold, but once it gets to temp doesn't ignite again and hot tap soon running cold. It does not appear to be heating the water in the storage tank, the second the burner stops so does the hot water. Hot water pressure/flow is still ok. Does this point to the blending valve / pump or other?? Many thanks
