I have two questions that I can't see a definite answer to elsewhere.
1) Do I let the first application of jointing compound filling the gap between plasterboard panels dry, before the tape goes on embedded in the compound? It is clear that the tape will need to dry before applying further layers on top of it.
2) Should I rub the joint down after each layer or only once I have applied all the layers?
