I keep having pinprick leaks from Yorkshires.
I clean each end of pipe so it is bright
smear an even amount of flux around the pipe ends
place yorkshires on
heat up
apply some extra solder in an attempt to get the bright ring
I am using a large blowlamp rather than one of those little direct ones.
On verticals do you sweat up the top ring or bottom first
Any hints would be appreciated.
place yorkshires on
heat up
