My 1.6 comfort Zafira is intermittently showing the battery light. This causes the dash lights to dim and the PAS to cut out. The light does go out after about 15 seconds but its happening more often, can happen after starting with heaters on etc or just driving under normal load.
Battery voltage is good and so is charge from alternator when light is not on. I haven't managed to test it when the light is on but would assume it would be less.
I am going to check the connections on the back of the alternator for tightness if I can reach them. Are there any other tests/checks I can do before attempting to replace the alternator?
What is the best way to remove the alternator? I'd need to remove the air box and then the bottom bolt but I hear this can hit the inner wing. Do you remove the bottom bracket and then bolt at the top bracket? Please could someone let me know how to remove the alternator to give me a head start. A local garage want £280 to supply and fit and I cannot afford that.
Thanks in advance.
Dan
Thanks in advance.
Dan
