Zafira 1.6 16V 1999
I was supplied a new alternator belt that is 5mm shorter than the recommended. Will this be OK to use? The car has an automatic tensioner on it.
When I replaced the drop link on the passenger side I noticed some up/down play in the track rod end. Not in the link but the nut seems to need tightening up. There is about 2mm of movement. I have attempted to tighten using a jack to force the link to not spin but the nut seems rusted solid. I think it has been like it since purchase and it doesn’t knock/steering/trackings fine. Do you think it is safe to leave it?
Zafira 1.6 16V 1999
