This relates to a zafira b, 1.8 petrol, 2012. I recently had the steering completely replaced after it failed. worked for a while and now it has intermittent power steering loss. it can be fine then suddenly goes heavy. mechanics have no idea and have basically advised against starting the work due to cost (recommending sending off parts for testing, cant do correct tests as its intermittent - one guy said its the pump but find this hard to believe as its brand new. )
I tested the alternator and all fine. someone mentioned it may be a wiring issue, or the ecu which makes more sense or even linked to abs sensors. The issue is I cant give to a mechanic as they are basically saying they have no clue and will need to replace parts one by one and it may still not fix the issue (£££££). Car only has 70000 and runs like a dream other than this. I'm happy to try myself as I can't see my expensive car sold for peanuts all because the steering cannot be fixed.
any ideas much appreciated
