On some of the Zanussis the heater wires are prone to fall off because the spade terminals point downwards. If the problem is heater related it should go through all the rinses and final spin without sticking.
if you can hear a clicking noise .....then i would say its the timer sticking ... ( if the noise is comming from the timer) stick your ear on the timer knob to make sure.
it is quite common on some zan models
its normaly the green cog inside the timer that stips
