Zanussi 1050
6 Jun 2005
Aberdeenshire
Hi. My Zanussi 1050 washer is having troubles with the spin cycles (not working). Machine will fill and drain. Drum will not rotate during wash cycle. Drum will rotate a few times prior to spin cycle (distribution), but will not spin. Checked the brushes, they're fine; checked the pressure switches, they're working. I figure it might be either a timer or speed control module problem. Could anyone please confirm. If it is the speed control module, how do I access it (I don't have my manual anymore)? Is it worth getting another one or get a new w/m (I'd rather not be wasteful)?
Any constructive advice is appreciated.
Thanks in advance
Sounds like a timer fault to me. If you are confident to remove and refit the timer, it is possible to send it away for test / repair. If you email me I can sort out a couple of repairers you can contact.
_______________________
moderator
email address removed, these can be shown in your profile
