this is a co-incidence surely. My Zanussi stopped spinning today. Will not spin the drum at any stage of the operation from switch on the end of wash. All clothes drenched on removal. Put it through a cycle and observed,- drum never turned. I investigated, drum is free to turn, turning motor is free to turn, belt is in perfect conjdition.
I think it mus be the motor, or a relay switch which activates the spinning action.
What did you discover.
My Zanussi FL1085 stopped spinning today.
If I select Spin, you can hear the water pump running.
I believe this means that the pressure switch has failed, or the tube to it is leaking, so that the machine cannot detect that it is empty of water.
