I concur with Pat-UK, what do you mean EDIT.
Is it short for a technical meaning or do you just like to see your name on the screen.If you averagejoe cannot give constructive advice on my problem don't give any,I aired my problem in the hopes that someone may have come across the problem before and would be able to advise, not so that people like you can think up smart alec replies.
Thank you to the people who have given advice so far.
_____________________________
Maybe he changed his mind?
sorry for the confusion i did leave a comment but then realised that my machine had a slightly different number i couldn't remove so deleted my comments, didn't mean to upset anyone.
What i actually said was that my machine had the same symptoms and it was the door interlock that was faulty, kept missing programs out as it went through the cycles i.e would empty the water but would not spin on occasions hope that clears up the edit comment
many thanks for the help given but had to call in a repair man who stated after checking it all out that it was a circuit board fault he took the offending part away and had it repaired and returned just before 5pm fitted it all back together and its now working at full strength catching up on the washing
