Thanks Breezer, We did as you suggested. outlet pipe completely blocked and kept on blocking. There is a ball in this pipe ( to stop coins?) We removed that temporarily, still kept blocking . Finished up with washer outside in garden, opened the pump trap and flushed inside drum with hose pipe. Outlet pipe still kept blocking. Took nearly all day before we got it cleared. Message is clear, washers are for clothe not mats.
