zanussi 1400 washing machine - won't heat water
7 Jun 2005
Norwich
I have a zanussi jetsystem 1400 washing machine. I noticed a few days ago that things were not coming out of the machine as clean as usual. It turns out the water is not being heated at all (i have run a 90 degree wash and stopped it at a number of points opened the door and the water was always freezing). I thought if the heater was broken then the machine should stop but it does the whole wash. Could it be the thermostat? (though i would have thought this would mean the water was always hot?)
Is it worth me getting an engineer out to look at it or is this going to be one of those things that costs more than a new machine?
thanks
jenny
the machine is quite a number of years old, and is definitely not still under warranty. What do you think is likely to be the cause of the problem?
Thank you
jenny
The thermostat or thermistor can fail where the machine will think the water is hot. If it's one of the "computer" controlled machines it could be a faulty pcb. As to cost of repair, you'll have to phone around for prices.
