Zanussi dw 907 not filling/overheating
10 Feb 2007
Kent
Hi all I hope you can help me.
I have a Zanussi DW907 dishwasher which is 10 years old.
It has occasional overheated but after cleaning the grey "base filter"it has been ok.
it has not been working too well and has been getting very hot.
after reading a post (zanussi too hot) I followed keithwashermans advice and cleaned out the three pipe under the pre filter.
All to no avail
I cleaned out the housing of the pump(?)- the green propeller thingy that the arm sits on.
still no joy- the propeller is turning but there is no water coming in.
the water (cold only) is feeding to the machine.
one post mentioned cold water valve being stuck- could it be this? if so where do I find it?
if its not this any other ideas.
finally in your considered opinions is it worth spending on a call out fee plus parts for a 10 year old machine whena new one is around the £300 mark.
all answers much appreciated
Andy[/u]
Inlet valve is locked in closed position due to blockage somewhere in your system.
Most likely in the fill matrix.
Could be a fairly cheap repair depending on where the blockage is but could turn out to be very expensive if new matrix and inlet valve is required.
Only you can decide whether it's worth spending on a call out to find out whether it's worth repairing or not.
Thanks sleepyhead
is this something I can investigate myself at all?
ta
