My roughly 10 year old Zanussi DWS 949 has stopped working. When I turn it on, I do not hear the usual gush of water entering the machine. At the usual point in the cycle when the arms should start spinning, I can hear the motor running but nothing happens. Also if I leave it on for long enough, the bit of water that is still in the machine does heat up (plenty of steam) but like I said, no spinning action whatsoever. When I turn the machine off, it seems to take quite a long time for the motor to stop spinning which would indicate that there is nothing resisting it to slow it down.
Could the problem be:
- A blocked inlet hose?
- A faulty inlet valve?
- A faulty pump?
- Faulty gearing/belt (if such things exist)?
Please advise how I can diagnose the problem further and hopefully fix it. I am reluctant to call an engineer in at this stage but I am getting fed up with washing dishes by hand as well.
- A faulty pump?
