Zanussi FJ1040 Conditioner tray not flushing
16 Feb 2005
Lancashire
This seems to be a common fault but I have not found a solution so here goes again.
No water feed to flush out the conditioner. The tray is clean and the siphon works on testing externally.
I would appreciate knowing why there is no water feed to the conditioner section. I have poked nylon line into the feed nozzles but no water feed results.
Do you think it is due to a faulty solenoid, if so how do I get to it?
Suggestions appreciated.
Regards flounder
:eek: :(
What I don't know ..... are there other readers on this forum or am I the only one reading my own postings?
A simple message would confirm that, although there may not be an answere to my problem, at least it has been read :oops: :cry:
Regards, flounder
I've read it and have no answer. Sounds like an electric valve not opening though. Could be valve, could be programmer, could be wire fallen off.
I've only ever had them clogged with congealed conditioner, which you say is not what's happened.
Thanks JohnD
It went so quiet that I thought my post was not getting out :eek:
Will have to try to get a circuit diagram to find out if there is a relay, solenoid etc in the flush.
Thanks JD
