Zanussi FJS 1025 washing Machine bearings
22 Aug 2006
Lancashire
I inherited this machine when moving house. Over the last few months we have noticed small black circular stains occaisionally on washing, similar to the pattern of holes on the inner drum. The machine has now started to knock on spin nd the inner drum has some play in it. I'm guessing the bearings have died. My question is how and how easy is it to replace these? Do I need to remove the drum completely or can I replace with outer drum in situ? And if so do I go in from the front or the back?
Argentum
Fairly sure, but not 100% you have to completely remove assy. & split outer drum in 2. The cover splits in the middle down the sides AIRC & you will need to disconnect the door seal at the front
