ZANUSSI FL 1032
16 Jun 2008
Oxfordshire
My washing machine has been filling up with hot water from the inlet pipe, then leaking out through the door. I want to know if i can run this machine just using the cold water inlet pipe?? As otherwise it is ok, spins ok, the excess water spins out ok. so no problem there. Can anyone advise me please. :)
The machine should work OK on the 40 degree washes with the hot supply to the machine turned off but I don't understand why you want to do this :confused: If there's a leak it will still be leaking whether hot or cold. Do you mean water is running out the front of the soap drawer? If so you need to remove the drawer and give everything a good clean, including round the holes where the water sprays into the soap compartments.
It is the hot water valve that has gone apparantly..so i have turned off supply. Spoke to a zanussi customer sevices person, and they said the mach should work ok just with cold water as it will heat up in the machine.
The water was leaking out of the door when it was closed. I will clean out the soap drawer as this is a bit clogged. I have run the mach on 2 loads since and it seems to be ok for now.
Thanks for your help :)
If using the 60 or 95 degree wash you may find you need to start off on a 40 degree wash and reset the dial to the higher temperature programme when it has finished filling with water.
