Zanussi FL828 Washing Machine overfilling with water
5 Nov 2007
Clackmannanshire
Please help just fitted a new drain sump hose with machine lying on its side.First wash at start of cycle the water kept filling up in machine till it started coming out of soap drawer.I shut it down and set it to empty.Any ideas of problem.
You may have filled with water the pressure sensor that measures depth of water. This could mean the sensor cannot measure the water level.
A unit fitted somewhere about level with the top of the drum and connected to the base of the drum with a small hose pipe. Will have a cable or a few wires going to it. Probably on the side that you lent the machine towards.
If there is that type of sensor than check the hose is empty, if not pull of the sensor to let pipe and sensor drain out.
