Zanussi Fls 1183W WM
13 Jul 2004
Dyfed
Please help.
Does anyone know why the belt on my above WM machine keep slipping off. Could it be the suspensions which holding the drum malfunction. If I change them, will the belt keep in place, or how do I adjust the belt angle or the tightness of the belt.
Many thanks
The drum & motor will be on the same axis, check the tension of the belt, it should be pretty tight - about 1/2 to 1 inch play along the longest run with mild finger pressure?
