Zanussi Motor Tacho magnet coil
8 Feb 2005
Help. Does anyone know where I can find and buy a motor tacho magnet coil for the Zanussi WJS1197?
CaesarG
hi m8
if you are anywhere near epsom,surrey you can pick one up from me FOC
hope that helps
will
Will,
Thanks for the offer. I live in Battersea. Is the tacho magnet coil a weak circular magnet mounted on plastic screw to fit abotut 5-7mm thread hole? If the answer is yes, when can I pick it up?
Sorry for bothering you with so many questions since you are giving it away FOC.
CaesarG
The tacho magnet is the black round thing with a plastic shaft that turns with the motor spindle. The tacho magnet coil is the bit with 2 wires coming out of it that surrounds the tacho magnet and is attached to the motor casing.
