Hi all
Wonder if anyone can shed some light on this. When the m/c was turned on there was water entering for a few seconds, then the RCD on the ring tripped. Reset that and changed fuse in plug top. Apart from the on light , zilch. Took the top off and noticed burnt out tracks on the timer pcb, which I have repaired, still zilch. I suspect burnt out tracks on the underside, but how do you get the front panel off and the timer out? It may well be that it is beyond repair, but it's worth trying before ordering a new one.
TIA
Martin
TIA
Martin
