Zanussi washer dryer
31 Oct 2007
Edinburgh
My girlfriends 7 year old Zanussi condensing washer dryer (Turbo Dry 1200 W1242W) has stopped pumping out the water. Do you guys think it is worth repairing? Also is there any other component it could be apart from the pump? like program dial or control circuit etc.
If it were the pump I could probably swap this out myself if the parts are available.
Thanks in advance people.
no just the pump/filter found at the front under kickstrip ,also check sink waste if its on the sink spigot,
Thanks.
Will check these things tomorrow. Never considered the filter at the front :eek:
Do you guys get a lot of calls only to find (at the embarrassment of the owner) that the filter is blocked?
Just thought I would let you know what the problem was.
Blocked strainer at the front..... :oops:
Thanks again rocks1
good , yes get loads of blocked filters your not the only ;)
