Now a few weeks after the dishwasher, the washing machine has gone wrong!
It is coming up with E10 on the screen.
According to the Manual this indicates that it took too long to fill. Looking online this specified that it took longer than 3 minutes to fill and was most likely the water inlet valve.
My first thoughts were that I doubted this as the machine starts the cycle and you can hear the machine fill and visibly see it filling in the drum quite quickly - then it starts to spin, it then fails a few minutes after.
I took the top off the washing machine and removed the water inlet valve. I made up a test lead reconnected the water and tested each solenoid in turn, both worked flawlessly. I tried repeating 20 times with each and both worked fine every time.
I reassembled everything and put the machine on a quick (24 minute) cycle. I got bored watching when it got to 15 mins left and went off for a drink (it wasn't getting this far before so I hoped just the dismantling and reassembly had fixed it) when I came back about 15 mins later it was back to E10 on the screen.
Any ideas what it could be?
