Zanussi washing machine FJS 1225w - drum won't turn
19 May 2009
Warwickshire
Hi anyone, my 8yr washing machine won't turn drum. If left overnight etc., it will turn a cm only. Water pumps in/out. Jet stream hose not blocked. Thought fault with either motor, suppressor, control panel, even water pump. Will check pump make sure not blocked. Any thoughts anyone please?
I think you're right. When I get mhy finger in there and move it around motor works again for about 20 minutes only, then arks, sparks, squeels and stops, like a car alternator making fan belt squeel when battery is low, so I'm sure it's the brushes, but looks a bit fiddly getting motor off, looks like 4 srews. Thanks for your reply and will try tonight.
you can replace them with the motor on the machine but can be fiddly. If I have to take the motor off I usually remove the back of the machine you got more room then.
Thanks again, this is a one-piece case, so no back to take off, so will have to fiddle around. Will post my results, thanks.
