Zanussi washing machine problem
19 Nov 2009
Edinburgh
Programme can be selected but no water being taken in. Hoses are OK. Machine was fine two weeks ago when we went on holiday. Model is FJS 1225W jet system 1200
unless you holidayed for 12 months, will still be under warranty.
Check troubleshooting in manual that was supplied with machine if no quick fix, call the supplier up.
If you do tamper with it, it may make your current warranty invalid.
Thanks for that but we are well out of warranty. However, I checked the connections were good and firm and jiggled the hoses about a bit then tried again - it worked - so may have just been air or a kink in hose.
