Our Zanussi washing machine works and the moter and belt is fine but there is no spinning as the drum seems to be stuck or struggling to turn. It feels as something may be jammed but nothing. What could it be?
Have you tried taking the belt off to make sure it is the drum rather than the motor? The drum can seize if the drum bearings fail but you can get the same symptoms if the motor bearings fail.
Thank you for your prompt reply. Is the diagram of the drum on the web that I can get to look at and is it easy to unfreeze or should I leave it to the experts!!!
