I'm hoping someone can help with fault diagnosis on a Zanussi Washing machine.
The wash cycle proceeds as normal until it stops just prior to rinse. If the switch is moved on by hand the cycle will progress through rinse, spin and drain, as for a normal wash but stopping each time with the switch needing to be moved on to the next click by hand.
With the wash cycle started at 'B' or 'C', it stops usually at 'F', sometimes a little bit before. From position 'D' the cycle will not start.
The retail model is Aquacycle 1000 FLA 1002W. Purchased in 2002. I removed the timer switch (AKO type 513 316 132 0558 10) for inspection, the two PCB relays appear to be ok. I've cleaned the drain filter. I'm unsure what to look at next.
