Zanussi Washing machine ZWF 16070W help - E21 code i think
6 Jan 2012
tell u all i know in sequence of events
-yesterday found clothes soaking wet coming out of 1600 rpm spin.
(bad electrical burning smell around machine)
-suspected sock in pump etc sp drained m/cusing flexy hose at bottom. Found small debris inc small white plastic spindle -around an inch long in filet-not sure if part of m/c or kids toy!!! (could email pic if required to somone)
-tried to run spin cycle only -not working
-messed about and ran drain cycle and then spin cycle ok?
-Another load tried tonight but found it stopped cycle after filling with water.
checked forums and using start/pause btn getting 2 red+ 1 green flash
hinting draining probs? E21??
not sure about burny smokey smell ?
Any help folks would be greatly appreciated...
TREV
Burning smell may be coming from worn/arcing motor brushes.
E21 is a drain error, if there are no blockages anyplace change out the pump.
