Hello everyone
Ok the problem is this, m/c has been working perfectly (last used 3days ago) go to use it this morning and problems...begins to fill then stops, tried it on various progs and similar results with some changes ie. small spurt of coild water infill then one of the two big white V/v's click and the infill stops...... then does it again over and over...... Pumped out, drain clear, filter clear, but when I tried it again I notice that usually during infill the drum will rotate from side to side and carry on doing this till the correct level is reached, this morning no drum movement at all, so m/c carries on filling till it decides to quit... question.... could it be the motor brushes that is causing all this as I can not spin anything out either.... if so does anyone know if I can safely lay the m/c on its front/side to get at ther motor, and also would anyone have any idea how these brushes come out...they are not just sprung loaded as normal and appear to fixed VERY firmly....sorry for the length of post....
PS the m/c is fitted with a Sole motor.
