It stopped spining mid cycle, no noise, no sparks.
I have recently replaced brushes, it has been working as it should for 2 months since they were fitted.
Is there a seperate fuse for the main motor it could look for?
Regards
Sg
I have tinkered with the motor brushes to see if they had come loose, they are ok.
I tried the machine and on the spin cycles it rotates three times then stops with no further action, while the drain pump is functioning.
So it appears the problem is not with the motor, but somewhere else?
Help anyone?
What would the effect be if inferior non-original brushes had been fitted?
I requested original brushes, but looking at the connection area with the motor, there appears to be a dark coating of residue?
Would this make the machine faulty as described?
MOD
please see item 10a
Regards
Sg
Help anyone?
MOD
please see item 10a
