Zanussi ZDC8202P Condenser Dryer 'Tank' fault.
6 Jan 2021
I have a Zanussi ZDC8202P Lindo 300 Condenser Tumble Dryer that turns on OK, but when you press the 'Pause/Start' button, the machine beeps 3 times and the 'Pause/Start' light flashes red. It has done this previously, and after a good clean, has worked again. This time, however, that is not the case.
I have put the machine into diagnostic mode, and the 'Pause/Start' button flashes red when the chasing LED's get to 'Tank', so I assume that where the issue lies.
Can anybody suggest what a 'Tank' fault may involve? Apart from being full.
I don't really know where to start looking.
TIA.
Thanks for your reply. I don't really know how this model detects water level. The tank just has a plastic doofer in the hole that goes up and down with the water I assume. This possibly makes contact with something inside the dryer when the tankis full, but I can't find anything. It's a bit of a moot point at the moment as I've just plugged it back in after 5 or 6 hours, and it's working again. I'm thinking that maybe the pcb board is on the way out.
