Zanussi ZDI6053 Dishwasher Wiring Broken at Bottom of Door
27 Jul 2007
Leeds
Not sure what caused it...
Any ideas on best way to fix (aside from replacing wiring loom)?
Crimp on a "Butt Connector", short length of wire and another connector?
I expect I will need a short length of wire as there is no slack. I have some 1.0mm squared white flex (rated 10 amp up to 2400 watts) and 1.5mm flex (rated 16 amp 3840 watts)... can I extract a short length of the internal blue wire from inside one of these lengths of white flex and crimp?
Any ideas what the internal broken blue wire is rated for? I know it is 240 volts as tested with a multimeter.
Open to suggestions..
Regards
I would do the same as you, your wire size should be adequate, if the machine drew more than 16A it would blow the fuse.
