- Joined
- 13 Nov 2010
- Messages
- 86
- Reaction score
- 0
- Country
Hi
I have been told the error code ED4 means it could be either the main board, heater board or the heating element. I was also told it's commonly the heater element. Our machine is an ZWD12270W
The NTC appears to be fine as it reacts to temperature change. Tested with .a multimeter on ohms range. The element itself measured to be 30ohms.
I have two questions
1) does this mean the element isn't at fault and it's one of the controller boards? I was hoping it will be the element since don't really want to try troubleshooting the pcb. I'm not an engineer. Therefore I was going to just check any relays actually work. Otherwise leave it at that. I would say beyond that, it's not really serviceable by your average electronics geek.
2) Also I read the washing machine will actually work fine without it. However does this mean that the washing machine will be washing with cold water instead? Or is the water heated up by something else?
