Replaced the fan element but it still doesn't heat up. A continuity tester shows that the old element did have continuity.
Rest of the oven works fine, including the thermostatic control of the conventional oven. Seems to be only the fan element which doesn't work.
Took off the back and there was serious scorching of the insulation around the fan element leads. On the power board there is a touch of scorching on the plastic connector on the power lead to the fan element. Plastic by that connector is brittle. A continuity connector shows a continuous link from the connector on the power board to the fan element's neutral connector.
Any suggestions as to what I might do/look at next would be gratefully recieved.
