couple of quick questions that've been bugging me...
1) does a zero pressure governor in a boiler replace the air prssure switch or fan thermistor, to prove the fan is operating correctly, before ignition takes place. are zero pressure governors common nowdays?
2) does a system boiler (pump inside casing) have the l n and e from the pump wired up via the wiring centre like a normal system or is it pre-wired into the boiler's pcb and stats when the boiler gets its switched live?
