Zinsser Scrubbable Matt
27 Aug 2024
Used this a few years ago to paint the walls downstairs in our house.
It went on great and was really easy to use but i've noticed it is starting to peel in a couple of areas now - mainly in lower corners and around skirting.
This isn't a cheap paint and i've never had this before with other brands.
Anyone else had this with this paint?
Could be a few reasons it's peeling.
Skirting gloss can overspill on wall a bit when painted, so then the emulsion is applied over the gloss and it don't stick so well around skirting and architrave.
Might not be the zinsser but the coats underneath that are peeling.
Might be the caulk losing adhesion that was run around skirting.
You need to investigate.
It's neither of the two replies. Its a in a few places.
It's a strange one. I've bought some Zinsser Peel Stop to see if that sorts it out.
Just dig back to good.
Fill.
Sand.
Paint.
If it happens again you know it's not an adhesion problem.
Peel stop seals the lifting edges so when you paint the moisture don't get under and lift the paint
