Hi all,
I have moved into a one off built house, the heating is plumbed for two zones but the the actuator valves have never been wired. With most of the in place, I need a bit of help to finish the system off.
Here's what I do have.
2 X two way valve/actuators for up and down stairs heating (not wired to anything)
1 x three way valve for HW and CH (not wired to anything)
Hot water tank with two immersions. (immersions not wired to anything)
Currently the water is heated by oil burner.
There is a wall mounted time and switches for the sink/bath immersion power, currently not connected to immersions.
I am about to order 2 Honeywell cm67rf wireless room thermostats and receivers to fit to the up/downstairs actuators, and someone told me I will need a strap on cylinder thermostat to complete the system. But I'm lost as to how the 3 way actuator is used.
I would like to heat the tank with the boiler without heating the rads but also heat the tank with the immersion.
Can anyone suggest a suitable plan for this, thanks a million
[/img]
[/img]
