Hi, we are about to install a new central heating system and have received a couple of proposals. I would really appreciate some input from forum experts as to the best design.
We have a long narrow flat around 27m at its longest point. The pipes need to run above a false ceiling about 3m from the floor, or 1.5m from the comi-boiler. I have attached a PDF with three plans based on a two pipe reverse system (“the 3 pipe solution”) for the local loop and for the ceiling distribution:
(a) a simple loop from mid point to one end and on to the other end of the flat;
(b) a two zone design, with water heading off to either side of the boiler; and
(c) a 4 zone design which attempts to balance the number of radiators being served at each drop.
So the question is which is the best design? Or is there nothing in it given the lengths involved?
As a non-expert, I think the 4 zone design with local two pipe reverses loops is the best way to distribute the load on the boiler but a couple of installers have said a simple two pipe circuit with radiators placed in parallel and balanced manually via their lock shield valves is sufficient.
Our main concern is that we want to place thermostatic valves on nearly all the radiators so the initial balanced system may become unbalanced as the radiators disconnect from the circuit.
Many thanks in advance!
View media item 41271
