Hi, I'm hoping you can advise me best.
I've never attempted bricklaying before, but circumstances dictated that I had to. I have built several columns in my garden for a large retaining wall (all columns 450mm square and 13 courses high - course gauge stick taken from house)
PLAN VIEW
1. column1 6m from column2 in a straight line. At a right angle from column2 is column3 2 metres away.
2. column7 6m from column6 then 6m apart from column5. All these in a straight line. At a right angle from column5 is another column4 2 metres away.
I have joined these using concrete blocks slightly off centre from the blocks as a front skin is going to go on consisting of house bricks.
Columns 4 to 7 are spot on level with each other. My concrete blocks come up to the level I want on course 11 so I can build bricks on the front and they will all be level for what I want to put on top.
However, when I built the concrete blocks between column1 and column2 (the blocks are level), I am 10mm out on column1. So my question is: should I build my bricks level and so be out 10mm on column1, or build them course to course (and so slightly not level) on columns 1 to 2 and trim off the concrete blocks?
Phew. I hope that made sense. Thanks.
PLAN VIEW
