If I wanted to insert a metal rod (12mm diameter) into some concrete, what would be the best way?
Drill the hole, fill with some kind of sealant, stick rod in? Or drill the hole, just insert the rod?
It is in a foundation, which is going to have concrete poured on top between two skins of a wall. Or is this a bit over zealous?
