Concrete path
3 Aug 2005
Leicester
Hi, you guys have helped me so much in the past, I would love your advice again.
You may have seen my latest project:
http://www.diynot.com/forums/viewtopic.php?t=31272 and http://www.diynot.com/forums/viewtopic.php?t=31163
Thanks to all the advice on here, it is coming along brilliantly.
Well now comes the next part of the same project.
Can I just mix concrete and pour it in that (blue) part?
Thank you very much.
Assuming that your intended level will be below your weep holes, I can't see why not. If you have some handy, you may find it useful to put some polythene sheeting over the front of the wall. Once you're concrete infill has hardened a bit, you can then run a stanley knive along the to cut the sheeting at ground level. This will save the front of the wall getting splashed as you lay the concrete.
