Hi, hoping you can help again!
What specifically should I use for weep holes in a retaining wall? Someone mentioned copper would degrade, albeit over a long period of time. So shall I use the equivalent plastic pipe used in plumbing, or a type of waste pipe? And should there be some kind of membrane to cover the end so the back fill gravel doesn't fall down it? Or I thought about covering that bit with rubble. As you can see I am not sure.
I don't know what I'd do without you lot - thank you for any help!
