- Joined
- 3 Mar 2007
- Messages
- 32
- Reaction score
- 0
- Country
I am installing a Miele KM548 Ceramic Hob.
The Hob is rated at 6800w. I am undecided if to use 4mm or 6mm cable.
Any advice on what is best would be appreciated. The cable will run from the RCD protected side of the MK Consumer Unit into the loft then clipped on the beams to the kitchen. The wiring will then go down a chased chanel to an MK 32a isolator with neon. The to a cooker outlet plate.
Total of run approximately 10 metres
Cheers
Cheers
