SWA Earthing
90°C XPLE steel wire armoured cables
This chart shows which (90°C XPLE) SWA cables comply with Table 54.7 when using only the armour as the CPC:
Green = compliant, Red = Non-Compliant
Notes
  * A cable which does not originally comply can still be brought into compliance with 54.7 providing an adequately sized additional earth cable is run in or a core is doubled up with the armour.
  * If the cable does not comply with table 54.7 it may still be used if it complies with the adiabatic equation.
70°C PVC Thermoplastic steel wire armoured cables
This chart shows which (70ºC thermoplastic) SWA cables comply with Table 54.7 when using only the armour as the  CPC:
Notes
Page Options
Wiki
Search
Create or Find Page
