Click here to go back to Single Way Lighting
Notes,
Chock block for the light fitting must be enclosed in fitting or in a suitable enclosure above ceiling which is accessable for inspection. The chock block must not exposed to heat from the lamp.
If a metal light switch is used, connect the earth wire to the earth terminal on the light switch and loop to the back box.
