Using Terminal Block enclosed within the light switch:
Click here to go back to Single Way Lighting
Notes,
Chock block for the light fitting must be enclosed in fitting or in a suitable enclosure above ceiling which is accessable for inspection. The chock block must not exposed to heat from the lamp.
If a metal light switch is used, connect the earth wire to the earth terminal on the light switch and loop to the back box.
Page Options
Wiki
Search
Create or Find Page
