Please note these are not definitive definitions they are meant to give some guidance.
Automatically vents air from system whilst filling.
AAV’s have to have their caps left unscrewed for them to be able to let air out.
They are used at high points in pipework where air could collect. Sometimes, for example in or near boilers, they MUST be left permanently open.
When they get old they are inclined to scale up and leak water out, in which case they should be replaced.
Note that when the cap is left undone they will let air in if the water is drained from the connected pipe, which can be useful for draining a system.
by ChrisR
Allows air to pass in only one direction - into the soil and drainage system. These are NOT normally referred to as AAV’s
Big ones (which fit 100mm diameter pipe or above) are often known by the trade-name Durgo.
They are designed to let air IN to waste or drain system, so that siphoning does not occur. Such siphoning can “pull” the water out of a trap so smelly air passes upwards. They do NOT let air out.
Individual fittings are available from 32mm diameter up, or they can be built in to a trap, such as the one below - the little part which looks tacked on the top is the Air Admittance Valve. The traps are known as Vented or Anti-Siphon traps.
by ChrisR
Connects beetween the flow and vent on open system to assist in air removal
Lets air into a room or compartment for combustion or cooling
Valve which opens the bypass automatically to suit system demand.
Natural draught room sealed appliance.
an appliance used to heat water (also see cylinder)
process of removing air from the system by opening bleed points on radiators and pipework
pipe linking the flow and return of a boiler used as a means of dissapating exess heat (also see auto bypass)
used to change the flow of water within a combination boiler between heating and hot water
combination boiler where both the heating and hot water are produced in the same appliance
burning of a fuel
non return valve ie only allows flow in one direction
pipe connecting the feed and expansion tank to the system
tank for producing / storing hot water
electric heater for hot water fitted in a cylinder
tap with square head and spout to fit hose to (usually on lowest point in system)
used to assist in venting and allowing expansion in a open system (1 size larger than feed)
used on a sealed system to absorb the expansion of the heated water
flue fitted with a fan to assist in the removal of products of combustion
used to fill a sealed system (usually a silver braided pipe with a valve at each end )
passage of heated water away from the boiler
system where the hot water feed and the heating are pumped if it uses two zone valves it is usually refered to as S plan if i uses a diverter valve Y plan (see also motorised valve)
system where the hot water feed is moved by convection and the heating is pumped (usually)
primary heats the water directly from the fuel being burned, secondary or domestic used to heat the hot water supply in a combination boiler usually water to water
also known as overheat stat switches the boiler off if the system gets too hot
A DESIGN PRINCIPLE/feature required by Building Regulations, which prevents a boiler from firing when there is no call for heat. (see Heating Controls for description)
Valve driven by a motor, 2 port usually called a zone valve
Valve driven by a motor, 3 port usually called a diverter
system that is vented to atmosphere (usually to a feed and expansion tank)
appliance that draws its combustion air from the room in which it is fitted
device for circulating heated water round the system
extra thermostat to keep the pump running after the boiler shuts down to dissipate heat
timer to turn boiler on and off
thermostat and programmer built into one unit
spring loaded valve to release exess pressure usually set at 3 bar
water returning to the boiler to be reheated
appliance that takes its air supply from outside the space it is fitted
system sealed from atmosphere (no tanks)
boiler with the pump expansion vessel etc built into the case
device for controlling temperature (room)
device for controlling temperature (cylinder)
vent supplying combustion air
see motorised valve
