I have just pulled up a poorly laid wood block floor, the floor it is to be laid on is a concrete floor which is not to level, is it ok to put a self leveling compound down and then lay the floor on to that?
will i need to seal the floor before applying the screed and then will i need to seal the screed before applying the the woodblocks and adhesive.
Any advice greatfully received
ps is there a technique for laying the woodblock, do you start in the middle, a corner?
