there may be no head in the flat, the tails may just enter the meter.
If it was me, I'd be ringing the DNO first thing in the am anyway
Indeed - that's what one would expect if those 'tails' did originate at the 3-phase head we've been looking at. However, as I've said, we've been told (rightly or wrongly):there may be no head in the flat, the tails may just enter the meter.
and there is a fuse there [in mum's flat] that can be pulled out in order to fit a new meter.
On that we can definitiely agree! Indeed, from what the OP has said, if it were me I would probably have called them at least 10 years ago!If it was me, I'd be ringing the DNO first thing in the am anyway
No need to presume ...I presumed it was a different building, not the same one
...and it is my mothers flat i stay around the corner in a council flat
It does have relevance, and therefore doesn't beggar belief, given that what the OP said when he first posted it was that he thought that his mother's setup looked the same as his. I suspect he was probably wrong in that recollection, and hopefully we will find out in due course.It is. I didn't pick up on that but quite frankly it beggars belief that someone would post a photo of their CU, not only in a different flat but in a different building as if it could possibly have any relevance.
I can't see that there can be any doubt about that!It looks like the 2 newer grey cables in here are live and neutral
Indeed so.they can be seen heading out of the white box, along with an earth which is clipped onto the bottom of the white box, to the newish grey box with the lever on in here
Indeed - and, as I've been saying, can we even be sure that those other ('old') conductors are still in use (i.e. connected to anything), or even that there are fuses in all three of the carriers?So that leaves the mystery of the remaining 4 lives (plus the small intercom live) and the 1 remaining neutral (plus the small intercom neutral). Could the single neutral be split off at a different point?
I would say not, at which point, as said, it sounds like an electrican needs to have a good look over it....can we even be sure that those other ('old') conductors are still in use (i.e. connected to anything), or even that there are fuses in all three of the carriers?
Kind Regards, John
Indeed - but it seems that the concern of the OP (or his mother) is that the (direct or indirect) consequences of getting the DNO in may not prove to be free!I would get the DNO in in the first instance, they're free!!
